Author Topic: Resistance Training for Kayaking  (Read 26399 times)
« on: November 26, 2012, 14:08:13 »
1: Injury Prevention
Now that people are starting into more difficult whitewater it might be useful to start thinking of injury prevention!
A dislocated shoulder is normally the end of your kayaking for ever irrespective of how much you love the sport I know of very few people who have managed to come back from one successfully.
Your shoulders play a massive part in kayaking and people mightn't know but your shoulder is held in place by a number of really small muscles! Primarily the muscles of your rotator cuff and trap3's. Rolling and bracing when done sloppily or without perfect technique place massive pressure on these tiny muscles and if they can't cope you can dislocate your shoulder... so below are a few really simple exercises I fit into my day that you can do at home to toughen these guy up.
These are tiny muscles and these exercises should be done with perfect form not worrying about the weight. For instance i do these regularly and I only use 5kg or less so for some of you a bag of sugar(about 1kg) might be enough to start with.
So try 3 sets of 10-12 reps of two of these guys a day. (i didn't bother listening to the sound in these videos as the movement is whats important)
1. External Rotator Cuff
http://www.youtube.com/watch?v=zbmyh5L4KeQ
2. Trap 3
http://www.youtube.com/watch?v=F0pO86z0Jpw
3.Rotator cuff
http://www.youtube.com/watch?v=RcQogAS5638
http://www.mensfitness.co.uk/exercise/shoulders/2677/cuban_press.html
Remember you have a free gym on campus these can take as little as 15mins to do and if done regularly will bomb proof your shoulders from any of the retarded moves you might try!
If people have any interest I can post a part 2 with a simple Core routine for building up your abs and core muscles which also play a vital role in kayaking.
also if anyone wants a gym routine (or steroids) you should talk to Nial Finch by the looks of him he knows one end of a barbell from the other (also by the looks of him he'd know where to score you some sweet sweet juice)
« Last Edit: April 09, 2013, 02:33:50 by Maryanne »
Re: Resistance Training for Kayaking! Injury Prevention!! (part 1?)
« Reply #1 on: December 05, 2012, 14:14:27 »
The current thinking on stretching at the moment is that static stretching before something is BAD! warmups should be just that running, jumping, push up, those games you guys have pre river are actually excellent warm ups.
This can be followed by dynamic stretching see http://www.youtube.com/watch?v=KfEFc7hN4Dk and then the whatever kayaking you like
Following a river trip conventional static stretching is ok!
« Reply #2 on: December 07, 2012, 12:37:56 »
2: Bomb proof your CORE
Kayaking involves a huge amount of ab and trunk muscle work. These muscles in conjunction with your TVA (transverse abdominis, hidden beneath your six pack), intercostals (between your ribs) and lower back muscles make up you CORE muscles.
A forward stroke if done correctly involves very little arm push/pull and a large amount of trunk rotation. This means that a powerful kayaking stroke comes from powerful core muscles!
the great thing about training your CORE is that not only will it benefit your sports performance, not just kayaking, but it improves your posture and helps protect you from injury. so here a work your CORE at home routine
1. Front plank http://www.bodybuilding.com/exercises/detail/view/name/plank
2. Side plank http://www.bodybuilding.com/exercises/detail/view/name/side-bridge
3. Ab exercise 1: Choose one of any of the following list
http://www.bodybuilding.com/exercises/detail/view/name/bent-knee-hip-raise
http://www.bodybuilding.com/exercises/detail/view/name/butt-ups
http://www.bodybuilding.com/exercises/detail/view/name/alternate-heel-touchers
http://www.bodybuilding.com/exercises/detail/view/name/air-bike
4. lower back exercise 2
http://www.bodybuilding.com/exercises/detail/view/name/superman
5. Front plank
The bridges should be more concrete road bridge then rope suspension bridge. so if your finding that after a few secs your lower back is weakening and dipping then stop, take a break, and start again. Also any ab crunch type exercise should always be paired with a lower back exercise to prevent developing imbalances.
A sample beginner routine might look like this
1. 30 secs
2. 20 secs each side
3. 25 reps
4. 25 reps
5. 30 secs
NO BREAK in-between
repeat three times (3 times a week)
If you struggle with the times here start low and build up gradually. you'll be shocked how quickly you'll go from 10 second front planks to 3minutes!
The planks also work your shoulders and lower back so don't be surprised if your shoulders tire quickly when you first start.
This takes less then ten minutes and is well worth it in conjunction with shoulder protection will really help bring on your kayaking and help prevent injury (including kerry related drinking injury)
As per last post if you'd like to speed up your strength gain then talk to Finch about steroids he knows all the major brands and will help you pick ones that will fit with your typical training routine.
Feel free to post up questions. good luck
p.s. its a common misconception that huge amounts of ab work will get you a six pack! wrong. Get your body fat below 10 percent and bam instant abs! a help is doing your bridges, strengthening your TVA pushes your abs forward so even if you've got some insulation you might get some early 6 pack action (or at the very least a flatter stomach).
« Last Edit: April 09, 2013, 02:34:28 by Maryanne »
