Author Topic: NRS HYDROSKIN LONGSLEEVE (Body Glove)  (Read 12805 times)
Offline Dillo
« on: April 20, 2007, 09:44:02 »
Brand new Hydroskin Long Sleeve 2007 (size : Small)
Size Height Weight Chest Waist
Small 5'2"-5'6" 100-130 lbs 32"- 36" 28"- 31"
Specs
0.5-mm neoprene core insulates and protects.
4-way stretch PowerSpanâ„¢ outer layer allows easy, unrestricted mobility.
New ThermalPlushâ„¢ lining increases insulation, repels moisture, and dries quickly.
Titanium adhesive aids body heat retention.
Lycra underarms eliminate binding, making this top superior both as a single, outer layer or as a base layer.
DWR coating forces water to bead and roll off for decreased evaporative cooling and quicker drying times between trips.
€80
Contact Paul :0861672160
